93' cobra wheels, max width tire?
  • Thread starter Thread starter xplo89gt
  • Start date Start date Feb 19, 2004
xplo89gt
945
Boston, MA
Feb 19, 2004
  • Feb 19, 2004
I have 93 cobra wheels. Which I believe are 17x7.5. Looking to get new rear tires and want to put the biggest tires on them. I want maximum contact area, so obviously I'm not going to try to put too big of a tire on there. I have a 245/45/17 on there now, and I'm just wondering if a 255 would work or should I stick with 245?
Also while i'm on the subject of 93 cobra wheels. What can I do to the front so they don't rub when doing a full turn? I'm planning on upgrading front brakes soon, so I would like to consider things that would help it not rub as well as best braking.
P
punkrockracer
260
Long Island
Feb 19, 2004
  • Feb 19, 2004
I've got 255/45 17's on the back and they fit well, but they do rub if I take a hard corner. just out of curiosity, how did you mount your wheels? Did you use a spacer? My front wheels rub as well, I just sort of ignore it
xplo89gt
945
Boston, MA
Feb 19, 2004
  • Feb 19, 2004
Nope no spacer. I have just been ignoring it. Guess ill just stick with 245's in the rear. Someone told me if you have 93 cobra rotors it wont rub. Not entirely sure.
Lefty44278
284
Detroit, Michigan
Feb 19, 2004
  • Feb 19, 2004
The 93 cobra spindles stick out further than a regular fox. I have the same issue with rubbing while turning and i use spacers too. Matt90Gt's website might tell you which spindles to run with these wheels.
http://mjbobbitt.home.comcast.net/index.html
BlownStangGT
REPEAT
3,860
Lancaster, PA
Feb 19, 2004
  • Feb 19, 2004
I have seen people with 275's on them in the rear no problem at all
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Feb 19, 2004
  • Feb 19, 2004
If you want the full tread to maintain good contact with the road, a good rule of thumb is to have the section width of the tire not any more than 2" wider than the wheel width. 7.5" + 2" = 9.5". 9.5" is 241 mm (25.4 mm/in). The first number in the tire size is the section width. So a 245 is about as wide as you'd want to go with a 7.5" wheel while allowing the tread to remain in full contact.
speedstang91
29
Southern NJ
Mar 12, 2006
  • Mar 12, 2006
I had Original 93 cobra wheels on my old '89 gt vert. They rubbed at first and then I got my musatng shop to notch out the lowere a-arm to prevent rubbing at full tilt. It is only a small piece so I'm pretty sure there were no issues of less strength or I'm sure the guy wouldn't have done it.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Mar 12, 2006
  • Mar 12, 2006
I would sell your original 93 Cobra wheels and buy 3 sets of Replica's. As already mentioned, the wheels are made for the 93 Cobra, and not any other Fox. The 93 Cobra has a wider track. These wheels will stick in more and cause rubbing problems. www.wheelreplicas.com Jeff is a great guy. Give him a call and get the wheels that look IDENTICAL and will have the CORRECT offset and backspacing for a Fox body Mustang (minus the 93 Cobra). I have a set and they fit like a GLOVE!!
Nick
Georgia Snake
17
Columbus GA
Dec 19, 2010
  • Dec 19, 2010
Speaking of Cobra
For yall's consideration...I have 255/45-17's all around on mine and no issues. Pics attached or see my garage
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,114
224
Massachusetts
Dec 19, 2010
#10
  • Dec 19, 2010
  • #10
If they are original offset 1993 cobra wheels, just buy 1993 cobra front rotors
They are the same rotors, but with a 0.75" taller hat. It's like running a spacer, but much safer. The rotors will work with stock spindles and calipers
Out back, you should use either a 3/4" spacer, or a thbird rear disk setup which pushes the wheels out 3/4" each side
Georgia Snake
17
Columbus GA
Dec 19, 2010
#11
  • Dec 19, 2010
  • #11
Cobra Wheels
My wheels are original equipment and have been on the car since new
Cobra1741
152
#12
  • Dec 19, 2010
  • #12
i have a 93 cobra and run 245 45r17 on the front and 275 40r17 on the back.
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
