93 Coupe Drag Race Roller
roadwarrior
772
Harlingen TX
93 Coupe Original V8
Original Paint
All Black Interior
Car is stock suspension, No Mini Tubs
8.50 Cert Chomoly cage *****Extreme Workmanship On Cage Look at Pix
Parachute mount/ Simpson Chute
Steeda Billet Lowers w/ Weight Jacker
UPR Adj Uppers
Solid Bushings
UPR Anti Roll Bar
QA1 Double adj Rear Shocks
8.8" Rear lots of work done, 9" axle tubes, LCA mounts have been redone w/ 1/4" steel plate, alot of detail, Rear end is also braced.
SVO Rear Girdle
Moser Axles
C-Clip Eliminators
Aerospace Brakes 5Lug, rear has 5/8" studs
Hole Shot Wheels
New M/T ET Drag Skinny
All Autometer Phantom Gauges. Tach, OP, WT, NO2, Dig Volt
Fire System for Engine Bay 2 Nozzles and Interior 1 Nozzle
Window Net
Kirkey Alum Race Seat with 5 Point Rest, need to get re cert
Rear Backseat bulkhead panel
Cage has alot of details, more than your typical 8.50 cage
5 Alum fuel Cell
Aeromotive A2000 Fuel Pump/Filter
Aeromotive A2000 Fuel Press Regulator 13202
Fuel System All Braided Hose
Tubular K Member, A-arms
QA1 Front Coil Overs Ajustable Struts
2" Racecraft drop Spindles,
Steeda Bump Steer Kit
Rear Wings, w/ struts mount to trunk lid, so you can open trunk w/o removing pins
Has Rear Ballast / removable in the trunk
Flaming River Manual Rack & Pinion
Flaming River Battery Disc
Rear Batter Relocate
Hurst Line Lock
Nitrous Bottle Bracket part of Cage, Passenger Side
Tranny cooler w/ Quick Disconnect Lines
Every line in this car is Braided w/ AN Fittings or Quick Connect Fittings
Car has original paint, and has clear title
Switch in Engine Compartment to Turn over the Engine to adjust Valves
Rocker Switch inside to Turn Motor Over w/n Ignition to Abort a Run (N2O)
Lights Work
5" Cowl Removable Hood Zeus Fasnter
Car has it all, Car has been 8.60s with a 358ci Nitrous Motor in NMCA Real Street. As you can see in the pictures the car is well built. Look at the welds on the cage, they speak for themselves. The whole car is built like this. The cage has alot of details, and more than a typical 8.50 cage. In picture you can see where the cage ties into the upper control arms. Some use battle boxes to strengthen this area, the cage was built into to it, as is where the lower control arms do as well.
$9,500.00
281-250-9596 call or text, I have tons of pix
Probably Some Stuff
***A2000 Pump is not on the car anymore, but everything else is from that fuel System Is.
***The A1000 Fuel System was completely removed. It was a N2O Fuel System.
