93 mustang start up issues
  • Thread starter Thread starter b0199
  • Start date Start date Apr 10, 2005
b0199
  • Apr 10, 2005
sometimes i have to floor the gas pedel to get the car to start. 306, 24 lb inj,stock cam. tp set .97,timing 14 degrees. 155 fuel pump&vortech inline. fuel pressure set to stock range. Also have a warm engine smoke out the tailpipes at startup. Pcv is new, no vacuem leakes. Gt 40 intake with 65 mm explorer tb, 75 c&L meter. Plugs are one stage cold set to .30. Stock coil 2 years old. any ideas.
70lightning
205
in the basement makin stuff
Apr 10, 2005
  • Apr 10, 2005
Is it throwing any codes? why are you running the colder plugs?
b0199
  • Apr 10, 2005
I had the colder plugs in for nitrous. Took the nitrous off. No codes, No check engine light.
T
TheUser
1,859
Springfield, MO
Apr 10, 2005
  • Apr 10, 2005
i'm kinda wondering why you have the plugs gapped to .030? Should be .054 or there-about. You should change to the proper plugs for your current setup w/ the proper gap. Might not fix your problem, but should run better.
Anyway, flooring the pedel while cranking cuts the injectors off, so it seems like maybe you have too much fuel. Maybe you're running a little rich? Is your MAF meter calibrated for 24lb injectors?
b0199
  • Apr 10, 2005
I had the plug gap at 30 for nitrous. So the nitrous wouldnt blow out the spark. Car has a stock ignition, No msd. MAF is calibrated for 24 lb inj.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 11, 2005
  • Apr 11, 2005
If thje IAB (or IAC) fails you will need to press the pedal to get airflow through the engine. Clean the IAB electrical connections, & the 10 pin salt & pepper shaker connections.
b0199
  • Apr 11, 2005
Thanks for the info. I will clean the 10 pin connections. I hope it works.
b0199
  • Apr 11, 2005
I cleaned all the connections on the 10 pins and the Idle air contol( IAC is new) Same thing. I changed plugs to stock heat range too. How can I test to see if Iac is failing? Example....If the car doesnt pop right off you can crank the car till the cows come home, and then as soon as you mash the gas...all the way it will start. Can I test when icrank the car during this issue assuming that I dont floor it to start the car?
HISSIN50
34
129
Apr 12, 2005
  • Apr 12, 2005
flooring it while cranking kills the injector pulse and helps clear a flood condition.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 12, 2005
#10
  • Apr 12, 2005
  • #10
Since you no longer are running the nitrous there is no need for the nitrous/boost gap...that will eliminate one more troubleshooter if you bump that gap back up or replace them. Get the right heat ranged plug and gap them in the lower .050's...
b0199
#11
  • Apr 12, 2005
  • #11
Plugs are set back to stock heat range and gapped to about 54. Timing set down to 12. Cap and rotor good. Fuel pressure set at 38 no vacuem. Issue still exists. The last time I had this problem I put a New Ignition coil on and It didnt do it for a long time. Any thoughts. Any good way to check a coil?
b0199
#12
  • Apr 13, 2005
  • #12
Found that the problem exists in either the distributer or the coil. I am sure replacing these will fix the problem.
b0199
#13
  • Apr 22, 2005
  • #13
Problem was not in the dist or coil rather the ect sensor. Fixed all problems!
  • dan50
  • Jul 18, 2026
dan50
Car popping car starts up but wants to die if I don’t hold pedal down
  • Creomod
  • Mar 25, 2024
3K
Fox 5.0 Mustang Tech Jun 16, 2025
AeroCoupe
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Idle spark confusion
  • sav22rem22
  • Oct 26, 2023
  • Digital Self-tuning Forum
2K
Digital Self-tuning Forum Nov 1, 2023
sav22rem22
N
Engine 1994 Mustang GT AODE puzzling issues
  • noah5slow
  • Oct 22, 2022
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Oct 29, 2022
noah5slow
N
