94 5.0 temperature help?? gauge is always too hot help help help????
ajay5605
9
any help would be GREATLY appreciated
94 GT conv is running really hot according to the gauge i drive it for a few miles then the guage goes up to the "L" in normal on the gauge sometimes even past that into the red. the car now has a new thermostat (180 degrees used to have a 195) and now a new water pump and new temp sensors both the gauge sensor on the intake to the right of the dizzy and the one on the coolant line above the thermostat housing
when i drive the car it gets too hot according to the gauge but when i pull the wire off of the sensor under the hood the gauge only drops to the "N" in normal not all the way to the "C" on the right of the gauge even when the gauge says hot (which sometimes it will creep all the way up to the red line on the gauge and maybe even a lil bit past) you can open the hood and touch the upper intake and both the top and bottom radiator hoses. when you open the hood it is def not overheating i mean its warm but def not way too hot
i cannot figure this thing out. i have no exhaust in the overflow tank and now white smoke and just did an oil change and the oil looks good flushed the radiator and all looked ok so i dont think its a head gasket the only thing that isnt new is the heater core hoses and the radator
any suggestions ????????????
PLEASE HELP
BTW i have bled the system (let it idle with the cap off and squeeze the upper hose and the fan appears to be acting fine comes on low when it is just a lil hott and on when it is hott with the air on
P.S.S lol
can someone with another 94-95 GT tell me what their temp sensor OHMS is if i unplug the one connector (to the right of the Dizzy) and plug a volt meter from the top of the connector to the ground side on the battery i start with 370 OHMs then as it warms up it goes down to 15 OHMs even though the haynes book says 74 to 9.5 OHMs
what does your sensor read???
You're better off getting a real gauge or means of observing temps because the stock gauge is so flakey anyhow.
You could check voltage at your ECT to see what temp the puter is seeing. The ECT should show about 0.80V at ~180*F, and about 3.0V at 70*F.
The ECT is a sensor on the passenger side.
The gauge sender is on the driver's side (one wire).
You'd want to test voltage at the ECT.
That's right in the neighborhood (it's actually a little cool, at just a hair over 200*F).
High should not kick on till in the 220's.
You could try a new sender for your gauge if you wanna keep using that thing, or go with an aftermarket gauge.
i already changed the sender for the gauge
how do you know what the temp is?? do you have a chart or something could you email it to me??
tomorrow i will pick up an aftermarket gauge and hook it up
and maybe pull the cluster to see if i can find anything wrong with the temp gauge
if you could get me the chart or let me know how you know the actual engine temp that would be great
If it really is running that hot, it's not abnormal. Remember while simply idling (stationary) the limiting factor is the fan coming on (because there is no ambient air flow over the coil [radiator]).
The low speed fan comes on at ~208*F so right in that neighborhood is where the car will settle. Once you start moving (or modify the fan settings), then it can come down if the thermostat will allow it (i.e. a 180* is used instead of a 195*).
thanks a ton for all your help HISSIN50
it was that stupid stock gauge
i went to autozone and got a $17 gauge and took the car out and it never broke 210 got close then came right back down
cruising at 45 the car was just under 190
i cant believe I did all that work (Waterpump, thermostat, and flushing system twice) to find it was the stupid gauge
thanks
