94-95 Hpipe on a fox?
  • Thread starter Thread starter 25thmustang
  • Start date Start date Jun 1, 2009
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jun 1, 2009
  • Jun 1, 2009
Thats about the extent of the question. I have an off road H from a 94-95 car, and have a fox I want to put it on. Will this work fine, or will there be some adjustments needed?
Thanks
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 1, 2009
  • Jun 1, 2009
Brian, it should work fine. Make sure the center section isn't welded if it's used because the headers on a 94-95 are a tad closer together so they could squeeze the 302 in the new body. You may just need to push that center section together more and clamp/weld it.
The BBK H-pipe I used from a 99-04 GT in Hack Job went right on. I also installed the 99-04 cat-back with no trouble. I had to trip the tail pipes, but it fit perfect in all the other areas.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jun 1, 2009
  • Jun 1, 2009
Good to know. I wont be installing the H-pipe, I will have a mechanic do it, and he wanted a heads up before tackeling it. As for the center I believe it is clamped, but has been clamped for a good 5-8 years, so not sure if that is going to budge. I guess my option is to have him do it, and pay him if it requires more work.
Thanks
SVT32VDOHC
3,501
28
119
Motor City
Jun 1, 2009
  • Jun 1, 2009
Thanks
Even if it's been clamped for a few years, he can just heat it up with a torch and it will come apart. Prolly won't have to get it cherry red, just get some heat, twist pull repeat. I try not to hit that stuff with a hammer, so I use a rubber mallet or a hammer with a block of wood.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jun 1, 2009
  • Jun 1, 2009
I will have to pass that info along to the mechanic. Sad day when I'm not wrenching on the car (my sisters GT) but I live 30-45 minutes away, and work 50-60 hours a week. I figure for $60-75 or so have someone toss it on, and do the same in 2 years for emissions...
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
