OK, here is the rundown. I have a '94 GT convertible automatic. The car cranks but will not start. I have gone through the manual following steps & replacing things as I go. I was not getting any spark anywhere, although I seemed to have power at the coil, module & pip plug.
The damn thing actually started up while a buddy cranked it and I was gounding/testing/backprobing the green #1 wire of the ign. module. Ran fine, started & stopped a few times then started bogging/sputtering a bit after about 5 minutes so I turned it off. The next morning, wont start again. So far I have replaced:
battery
cap & rotor
alternator
ignition module
coil
distributor pick up stator
I have also cleaned the MAF sensor. So before I spend a bunch more $$ can someone point me in the right direction, or tell me what to do. PLEEEZZZEEE
battery
cap & rotor
alternator
ignition module
coil
