In the process of putting a 88 fox 5.0 and t5 into a 94 v6 stang.
the trans cross member is approx 3" short of being able to bolt the trans mount to. Is a 94 gt t5 crossmember what i need? The 88 could work with a bit of fabricating. but Id like to just bolt in and go.
I already have the motor and trans in and driveshaft in. And the hood on.
Now the engine wire harness. Obviously is different so If I acquired a 94 gt wire harness would that just plug and play on the 88 5.0?
Im good on everything else the power steering line worked great with the 5.0 steering pump.
looks like I will have to do a little figuring out on the vacuum lines which i believe will be no trouble i am just going to use the vacuum tree from the 88.
I did find that im going to have to splice the fuel lines from the v-6 to make them longer to fit the 88 5.0
there on the passenger side and have the proper size hookup but they need to be approx 10 inches longer.
If anyone can steer me in the right direction on the crossmember and the wire harness it would really help.
Thanks for any help you can give.
Have a great day!
Have a great day!
