95 GT Code 12
95CanaryPony
Las Vegas
I just changed the spark plugs and wires on my 95 GT and now I’m seeing a code 12. I’m not sure if the two are related or if it’s a coincidence. I’m still a novice so I’m thinking I messed something up when installing the plugs. Perhaps a gap issue. However, the car isn’t misfiring from what I can tell and runs pretty good. Anyone know what could be the issue?
  • Sponsors(?)
95CanaryPony
Las Vegas
I am getting the code 12 on the dash via the airbag light. When I start the car, the airbag light flashes once then stops and then flashes twice. This process repeats about three times until the airbag light stays on all together. I interpreted this as a code 12. However, I could be very wrong. But I will check out that thread and see if I can fix the issue. Thanks for your response bro!
95CanaryPony
Las Vegas
I should have specified that it was an airbag code in the beginning. I read the forum you shared and it turned out I had a blown 10 amp fuse under the steering wheel. The owners manual said it was the fuse for the airbag module (aux. pwr). I went and replaced the fuse and it instantly blew again.
General karthief
Mod Dude
Aug 25, 2016
16,884
5,396
193
polk county florida
Are you disconnecting the battery when you fool around with the air bag? You do not want that thing going off when working around it.
pull the bag and disconnect the plug, then change the fuse, connect the battery and see if it blows.
jozsefsz
5 Year Member
Aug 11, 2013
1,143
271
114
49
Cleveland OH Area
Make sure your battery is fully charged. If the voltage drops below a certain level, the airbag system will preventatively blow the fuse to keep you out of harm's way. That was 90's technology at its best. :) There are other faults that will cause the fuse to blow, but that one's the simplest to check.
Here a good thread on the topic: https://www.stangnet.com/mustang-forums/threads/1994-mustang-air-bag-flashing-code-12.904822/
I posted the troubleshooting guide there way-back-when.
  • Useful
Reactions: General karthief
Thread starter Similar threads Forum Replies Date
D Codes pulled from mustang SN95 4.6L Mustang Tech 0
R Code scanner problem Fox 5.0 Mustang Tech 15
J Please help - 68 Convertible J-Code confirmation/value 1965 - 1973 Classic Mustangs -General/Talk- 1
D P0302, P0316, and P0171 codes with "new" 02 V6 1996 - 2004 SN95 Mustang -General/Talk- 9
E code p0234 "A" overboost condition 2015+ Specific Tech 2
M P1233 CODE SN95 4.6L Mustang Tech 2
D On Board Computer several Codes 2005 - 2009 Specific Tech 1
B Engine Codes 81, 82, 85 and 41 - Where to start. 5.0HO/AOD transplanted into '67 Fox 5.0 Mustang Tech 14
B Code 95 in Memory - 5.OHO transplant into '67 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
DaveRog Black Leather Interior Trim Code 1994 - 1995 Specific Tech 0
C Electrical Codes with and without chip Fox 5.0 Mustang Tech 0
T Fuel pump code issues 1994 - 1995 Specific Tech 5
7 Need 1988-90 lx body parts passenger door and maybe passenger fender ? My paint code is 7n thanks The Welcome Wagon 12
79pace 2000 GT Strong exhaust smell possibly really rich but no codes 1996 - 2004 SN95 Mustang -General/Talk- 4
J Fuel Code 452. Fuel pump not working. Help 1994 - 1995 Specific Tech 5
J p0453 code 1996 - 2004 SN95 Mustang -General/Talk- 1
splinterddt Multiple Misfire Codes 2005 - 2014 S-197 Mustang -General/Talk- 68
C Does a 2015 Mustang have a radio code? 2015+ Specific Tech 0
C Electrical 90 LX 5.0 threw these codes... Any ideas? Fox 5.0 Mustang Tech 3
B Engine code p0118 SN95 4.6L Mustang Tech 4
M 1967 s-code fan problem 1965 - 1973 Classic Mustangs -General/Talk- 2
F new member 1965 Mustang Fastback GT A code 4 spd The Welcome Wagon 4
M codes on 01 mustange 1996 - 2004 SN95 Mustang -General/Talk- 1
S Engine Code 63 and more shuddering Fox 5.0 Mustang Tech 10
S Engine Bad Shudder and Bad Codes Fox 5.0 Mustang Tech 2
S Engine Need help with fox body code results. Fox 5.0 Mustang Tech 0
T 64.5 D code auto to 4 spd manual trans swap advice/info needed Classic Mustang Specific Tech 4
1 Engine Check engine light with no stored codes Fox 5.0 Mustang Tech 5
R 06 mustang reading p0353 code 2005 - 2014 S-197 Mustang -General/Talk- 3
K Engine Tps code 63 troubles Fox 5.0 Mustang Tech 10
titanium1990 YJ paint code please help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 34
P Fuel code P0460 won’t pass smog SN95 4.6L Mustang Tech 11
M Please help with p1450 code 2015+ Specific Tech 0
4 Digital Tuning Backup Tune for 2012 Mustang GT, Computer Code ZFK0 2010 - 2014 Specific Tech 0
Eilermoon P0403 Error Code 1996 - 2004 SN95 Mustang -General/Talk- 2
Xenogenesis Engine Idles rough, misfires at idle, smells rich, but codes say it's lean on both banks SN95 V6 Mustang Tech 9
B 4.6L2V random misfire with no codes SN95 4.6L Mustang Tech 6
P Help new codes 4.6 swap SN95 4.6L Mustang Tech 4
P Help!! Open Injector Circuit Codes SN95 4.6L Mustang Tech 21
k19driver Engine ACT Code 54 "Sensor circuit open" Fox 5.0 Mustang Tech 7
F Drivetrain AOD to T5: random codes/issues Fox 5.0 Mustang Tech 12
C Airbag code 63 will not clear need help 1994 - 1995 Specific Tech 2
D Engine Codes P0155,P0135 SN95 4.6L Mustang Tech 5
M Electrical Need to Eliminate Code 85. Fox 5.0 Mustang Tech 11
J Engine 93 lx 2.3l runs terrible 2.3L (N/A & Turbo) Tech 9
D Code Reader Results Fox 5.0 Mustang Tech 4
S 1993 Mustang GT will not display check engine light until it is turned over and will not throw codes... Fox 5.0 Mustang Tech 9
P P0190 Code 1996 - 2004 SN95 Mustang -General/Talk- 3
91GTstroked Engine Code 29 vehicle speed sensor question Fox 5.0 Mustang Tech 5
0 PO345 Code 2005 - 2009 Specific Tech 2
