Ok fella's I think I have wired my clutch safety switch (bypass) incorrectly because the switch is faulty which is causing my car not to start. There are 2 Connectors that plug into the clutch switch and im not sure which wires to butt-splice together to bypass the switch. I basically looked at the 2 connectors plugged into the clutch switch and just butt spliced connector 1's wires directly across to the other connector 2's wires is this correct or should I have just but spliced connector 1's wires together and also connector 2's wires together instead of cris-crossing them? any info would be greatly appreciated thanks. Here's a blurry image but the best i could do of my current setup and I do not get the 6volts to the starter which the current configuration, I also checked the Ignition switch and its functioning perfect as well as the starter relay was replaced.
I wont be able to test anything until possibly tomorrow with switching around the relays. this has me so damn bummed haha been thru every wiring diagram and trouble shooting technique I could possibly think of. im leaning towards either an open circuit or the relay is shot thanks so much for the help man I owe you a drink.
