95 OBD1 Codes
  • Thread starter Thread starter 5.0Eleanor
  • Start date Start date Mar 19, 2010
5.0Eleanor
  • Mar 19, 2010
Hallo everyone im new to this site, and in search for help. I recently bought a 95 5.0 Gt all stock with a couple of problems with it When i try to accelerate hard on wide open throttle, it feels like its not getting gas, like it bogs a bit and the check engine light comes on. So i bought an OBD1 code reader and got these codes
on KOEO
CODE: 181,189, fuel system at rich adaptive limit at partial throttle / system lean
KOER
CODE: 172 HEGO (HO2S) Sensor Fault / lean
CODE: 213 Spout Circuit Open
On code 213 (Spout Circuit Open) i found out that one of the tooth from the spout cap was bent and was not inserted in right. Fixed that problem, and that code is gone. It Accelerates a bit faster, but it still feels like im losing power. What can be causing these problems?
HISSIN50
34
129
Mar 19, 2010
  • Mar 19, 2010
Clean the MAF sensor if you haven't.
Clear the codes and re-run them after a couple of drives. You might have a vac leak, MAF issue, or O2's that have seen better days. On 94-95s, bad O2's lead to some real driveability issues.
Good luck.
R
RatStang
544
  • Mar 19, 2010
After that... it may be worth the time and realtively minor expense, of getting your fuel injectors cleaned and flow tested. Rich at part throttle while lean on top leads me the idea that injectors may be clogged or that the spray pattern is lousy.
If you do get them tested, be sure to buy an o-ring kit for reinstallation. Some silicone lube would be nice too.
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
2K
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
