95' V6 rear?
TrickFlowd
240
Sayre, PA
Will this work on my 91? I'm swapping to 5 lug conversion, and already have the front spindles from a 94-95 along with cobra calipers and rotors. I found a 95 V6 rear for a decent price. Will this be good for 5 lug disc swap? Will my 4.10's from my 91 rear work? I plan to upgrade to 31 spline diff and axles. How much is the width difference from 87-93 to 94-95? :shrug:
I want to run 17x9.5 or 10.5 wheels in the rear...and 17x8 or 9 in the front.
Thanks guys!
Thanks guys!
use the axles and the brackets and stuff as the 7,5 and 8.8 use the same 28 spline axle just install them in your rearend
The brakes are the same as '95GT brakes, just the rear end is crappy.
Take the brakes off the rear, take the axle shafts out and chuck the rest. Swap that stuff onto your current 8.8.
If you want 31 spline just get an 8.8 31-spline diff (there are all the same 86-04) and order 31 spline axles for a 94-98 Mustang.
Now, if you want to change the offset slightly and pull the rear wheels in for 9" or wider wheels, you can order the north race car brackets and order 5-lug 31-spline axles for stock lenght fox Mustangs
