95Bluestallion's head swap pic thread
Nah, I don't think so...
You are drowning it even more by having the undersized MAF. Think about it like this...
A 24# injector puts in some fuel per pulse (keeping it simple, as pressure and duration will affect this as well, but conceptually it will be accurate). Lets say that is amount X.
A 42# injector also puts in some fuel per pulse. Obviously, when the 42# injector pulses, it pulses more than a 24# injector, right? How else would it flow so much more fuel? So, lets say the 42 # flows an amount of fuel equal to X + Y.
Now, X + Y is obviously bigger than X. Of course. Bigger injector.
Now, your 24 # MAF. It gets some air flowing over it. That air flow is translated into a voltage that is sent to the computer. Lets say at some airflow, that voltage is A.
Now, at out hypothetical airflow (whatever it may be), voltage A tells the injector to pulse exactly whatever our hypothetical fuel value X was. Now, what happens if you send the computer voltage A, but you have the 42 # injector in there? Well, the injector pulses X + Y fuel. You see the problem?
A calibrated MAF effectively shifts the curve of the MAF function. The MAF knows how much air your combo is sucking through it. That is its entire purpose. It sends a signal to the computer based on that air flow. Your problem is it is seeing some airflow and sending a signal that will deliver the proper fuel if you had 24 # injectors. You are way rich since the 42 # injectors are so much bigger.
Will the car be the BEST that it possibly can be? No. It will probably be hard as hell to start. Can you get it running really well by prudent adjustments of fuel pressure? You bet. I bet you it will do just fine once it is started.
JMHO, of course...
You have a valid point my friend. :nice:
Jinx, I already have the 42's in there now.
JJ, I didnt think to pull the spout. I'll try that for giggles. I marked the dizzy before taking it out, so it should be right at the stock timing assuming I got it put in with cylinder 1 on the correct stroke. Im pretty confident of that though.:D
Well like I said in my chip request thread, I got her to fire up and idle by pulling out my old chip from the computer. I dont know how it worked, but it did. I have the power steering bled at least, but I cant wait to get my chip and get it back on the road. I will have more pics and a couple videos once I get the chip!
Here is a video of the car starting up. I had to make sure the dizzy was still in all the way, cause I havent bolted it down yet until I set my timing. Dont mind me turning the wheels, just making sure the new power steering pump is fully bled. You can see that I cant really rev it or it tries to die, might be because of drinking twice the amount of fuel it needs, no EGR, no smog... not sure which one. :)
http://s298.photobucket.com/albums/mm276/Iowabiggun/?action=view&current=013.mp4
