96 SVT stumble, no chk eng light?
thecoop
Sup yall
question,
my buddy's 96 svt stumbles under hard acceleration, no check engine light like i said.
hooked a scanner up to it today and monitored data as we drove, when it stumbled:
TPS 93.3%
Load 98%
all 02's at about .850 mv
s/t fuel trims at about 11-14
fuel system 1 goes into open loop
then when you let off,
TPS 20%
Load 23%
all 02's go to 0.000 for about 5 sec
s/t fuel trims -3
goes back into closed loop
weird thing is TPS never goes below 20% even when fully off throttle and the load calculation never goes below 23% and when rolling into it goes right to 80%
Are these things known for bad throttle position sensors?
Any ideas?
CLean the MAF
MAF is dirty. Classic sign. Fuel trim neg at idle. Big positive at load. AF will go lean at application of power. There is a delay for the O2 sensors to detect the lean condition and add fuel.
Use MAF cleaner.
It is normal for the load numbers to never go below 20%. Not as sure about the TPS. There are posts regrading how to index/check the TPS. Might be a good place to start.
Somewhat concerned about the "Open Loop" at WOT. Normally, the PCM would not go into open loop unless a sensor failed/no signal. The O2's going to zero may be the failed sensor and the reason for open loop operation.
Is this a custom tune?
no custom tune. car is compeltely stock. I think the 02's going to 0.000 are a result of the problem since there are no 02 codes and all 4 go out at the same time. Never have I seen 4 02's go bad at once, not even on a German car! Lol.
Will try cleaning the MAF and see what happens.
Need to research more on the TPS signal and why its range is 20% to 93%, it never even gets to 100% under WOT...weird.
Thx.
I thought the computer swithching to open loop at WOT was normal? A/F ratio goes rich at WOT and makes the O2 sensors useless to the computer.
I think your TPS readings are fairly typical. 10~20 degrees maybe when closed mid 90s when fully open. I think people used to try to fine tune it to equal 100 degrees when opened but I don't think it matters as the computer calibrates itself to scale to the range of values it sees. I noticed mine sitting around 18 degrees closed when I had my scanner hooked up the other day, didn't think to look at WOT though.
