My friend jim did do a good job on that headswap writeup, but looks like your doing the entire engine.
i put a 00 engine into my 96 bird, things i needed to change was the flexplate, the 99-00 windsor engines have 8 bolt cranks them, the 96-98/01-04 romeo engines had 6 bolt cranks.
intake you have 2 temp sensors, new intakes only have 1, two options, 1- youll have to drill/tap the new intake for that 2nd temp sensor or 2- if i remember right you can order the aluminum crossover tube from the npi intake and adapt it to the pi intake. that way youll have 2temp sensor holes
cop vs wires, my engine had cop's all i did was remove them and keep the plugwires and 2 coil packs.
wiring everything that i unhooked from the 96 engine hooked up to the 00 engine
oil pan, i reused my tbird pan and pickup tube, the tbirds pan is different due to the kmember on the tbird is different than the mustang.
manifolds, i reused my old ones.
maf - makes no difference
ScottPuddintane said:
Anyone else?
These are SOME of the things I'm wondering about for the various years... does anyone know this stuff? What else do I need to know to make one of the swaps I listed?
1. Wiring differences?
2. When did coil on plug ignition start? How do I deal with this?
3. Oil pan differences? (I think I "heard" an '02 doesn't have a oil level sensor)
4. Exhaust manifold/cross-over pipe compatibility? Are they all the same?
5. water temp. sensors? Where/how do I mount my second sensor? What years have only one hole?
6. MAF sensor?
7. Automatic transmission/engine flywheel compatibility?
8. Various brackets?
Anything else????
What years do I need to get ahead of time for the swaps I listed?
'99,'00, '01, '02, '03 SOHC into a '96 Mustang GT SOHC automatic.
