97 gt engine swap
@97stang281 hey bud I just did that swap.. I used a motor out of a 2001 Lincoln town car.. same motor as the stangs but they had a much easier life.. no dogging on them. only thing I had to address was the intake it had the plastic coolant passage in the front. Also, you'll also need to modify the brackets for your coil packs unless you plan on converting to coil-on, and the front timing cover uses a different tensioner and belt routing than your 97. if you simply add a ribbed idler pulley to the pass. side of the motor and run a pi stang motor belt routing. you got ne questions just email me.
I just put a 2002 4.6 PI engine into my 1997 GT. It is actually a good and fast swap. You can drive it around just fine without even having a tune. The PI engine is a vast improvement over the NPI engine. But do not expect a 13 sec car until you have it tuned.
