98 Mustang Gt Car Alarm Issues
Quinn209
Im having alarm problems yesterday i locked my mustang with the keyless remote this morning it wouldnt unlock it i unlocked the car with key but my alarm wont stop going off and the car wont start Is there anyway i can bypass my alarm i really need to drive my car i pulled the fuse for the anti theft the light isnt on but my car alarm still wont stop going off.
I just changed the batteries in the keyless remote and it still wouldnt shut off the alarm
The alarm is tied into a gray w/yellow stripe wire under the column. From there it may be tapped into the door locks, trunk release etc. find the brain (usually above the fuse panel under the dash and start removing things. You should be able to just solder the main grey/yellow wire back together and start the car. Just undo what's been done.
I going to assume this is the Ford Factory anti-theft (PATS) system.
Turn the key on but do NOT crank. Does the theft light come at initial key on "lamp test"? If not, then the theft light is burned out or has been removed from the cluster.
Does the theft light go out after a 3 second "prove out"? If not, then stop and find out why.
Note, I suspect that the PATS key is not been read. Why? Because if it were, the alarm would reset.
Also, unlocking the driver's door with the key should reset the alarm. If it doesn't then suspect the door key lock switch isn't working correctly. It's a simple on/off switch mechanically driven from the lock. Suspect it has been water damaged due to age.
The alarm system also depends upon the door ajar switch. So expect problems if the door ajar switch isn't functioning correctly.
