  • SVT Tech Forum
98Cobra A/C question
  • Thread starter Thread starter MacDiesel
  • Start date Start date Jun 9, 2005
M
MacDiesel
74
  • Jun 9, 2005
i finally got freon into my A/C system and it blows cold air as it should. THis was yesturday. TOday on my way to work i noticed what looked like freon coming out of my air vents inside my car. does this mean that there is a leak, or what does this mean?
ak_sn8k01
44
Houston, Tx
Jun 9, 2005
  • Jun 9, 2005
Was the system completely empty or just need to a partial charge?
The freon coming out of the vents - is it oily or appear like dry/frosty air?
Oily = poss evap core leak
dry = system blockage
Turn off the a/c for awhile. After sometime turn in back on. Does it blow cold at first then begin to blow frost out the vents? More info please.
M
MacDiesel
74
  • Jun 9, 2005
it just took a partial charge. yes it blows cold air at first and then it blows frost out of the vents.
ak_sn8k01
44
Houston, Tx
Jun 10, 2005
  • Jun 10, 2005
Sounds like it's freezing up. Could be one of a few concerns. What are the gauge readings?
Sharp99
Eastern Washington (a.k.a the dry :poo:ties)
Jun 10, 2005
  • Jun 10, 2005
Leaky Freon
Freons are colorless and mostly odorless gasses at room temperature. It is more likely that the AC-discharge thermoststat is not working and what you are seeking is frost and water condensation from the vent. If you do suspect a Freon leak ask the service mechanic to put a UV-fluorescing dye into the Freon. When the mechanic (or you) check it the next day, any leaks will be real obvious under a black-light. Good luck.
Sharp99
A/C blowing defrost
  • 70/04mach1
  • Jul 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 30, 2026
Don7Up
D
Engine A/C QUESTION
  • Mindseye007
  • Jun 5, 2025
  • 2 3 4
2K
Fox 5.0 Mustang Tech Jun 22, 2026
nicholase
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
  • SVT Tech Forum
