98GT speedo calibration?
how do i know if my car has one , or just has a gear int he trans?
Two options.
1. Pull up your outer shift boot and look to see if there is a speedcal box in there, since that is where it would be connected inside the car.
2. Find the vehicle speed sensor - it's under the car, driver's side toward the back end of the midpipe. If you have a speed cal, it would be connected to that.
I ended up getting a speedcal over the gear because I could not find a gear for 4.10 ratio. I read that the number of teeth that gear would need would make it inherently weak and prone to breaking, so I think that is why Ford stopped at 3.73
Edit - Check here for some good pictures of where the Speedcal would be located if you had one
http://www.americanmuscle.com/speed-cal-install.html
