Haha, Scot with one t from TCS. I am Outrun on there.
Anyways, you need to grind some material off of the 94-98 spindle to accomodate the caliper and bracket. Not sure about the brake lines though, as I did a 5 lug conversion on my 86. Plus as started, the dual pot 99-04 calipers are made of aluminum as opposed to steel on the 94-98's. You save 10-15 pounds of unsprung weight off of the front end, which in my opinion any weight ssavings with better braking is a definate plus. I got mine from
www.car-part.com I paid 50 bucks for two 99 calipers. I cannot compare the 94-98 brakes to the dual pots because I was using the weak ass 10 inch brakes on my 86. Good luck!
If I was you Scot, I'd just can the front brakes and buy the 94-04 13" front Cobra Brakes. Much bettah stopping power.
