Is JUST the clutch bad? Is the clutch field coil good? If so, If this were my car I would buy a Ford name brand AC clutch and replace everything but the field coil. A simple pair of snap ring piles is all that is needed to remove the old clutch.
The real work is removing the pressed on field coil which is difficult/impossible to do with the compressor on the car. By retaining the field coil it's possible to fix the rest of the clutch.
This repair only works if the replacement parts are 100% compatible with the parts already on the car. Mixing and matching Ford Motor craft and Brand X replacement parts won't work here.
This is a public forum. I'm not going to tell anyone it's OK to vent Freon into the air.
