Hmmm beats me thenIf your TPS were out of range, you should be getting a code for it.
This thread does not state:
- Which CAM sensor type was used.
- HOW the CAM sensor was installed and aligned.
Still doing the same... so either I'm not doing it right or it's not it. Am I overthinking it? Just to recap I've checked Alternator , coil pack, spark plugs, plug wires, camshaft synch sensor, camshaft synchronizer, crankshaft sensor what else could it possibly be????!???Sweet... I also noted that he said it would make the motor run regardless of how it's set but it would only run correctly in one position.
also think my fuel pump is going badStill doing the same... so either I'm not doing it right or it's not it. Am I overthinking it? Just to recap I've checked Alternator , coil pack, spark plugs, plug wires, camshaft synch sensor, camshaft synchronizer, crankshaft sensor what else could it possibly be????!???![]()
Well the thing is the engine is a 2002 and I used the camshaft from my old 99*Silly question but did you get a cam sensor for the engine year or the car year?
