A/C Compressor......
gebasgt
95
This is a pic of my a/c compressor. What has happened and why? It still works but as you can see something has worn and I'm not sure what. Any ideas?
Yep, I had them both go out on both of my Mustangs. The last one I even changed myself. It is the a/c compressor clutch hub. I borrowed a couple tools from autozone thru their Loan a Tool program, bought snap ring pliers and tackled the job. I used a different type than the stock, but I did get it at Autozone for I believe $90.00. I always start with the parts store websites to get an idea what I need to know, part #, cost, and who shows availability. The hardest part was the snap ring pliers wouldn't open enough for the snap ring to open, so I cut a small wedge out of the pliers to gain a little more room.
It has been a while, but I remember borrowing a a/c clutch holding tool, a/c hub installer, a/c clutch puller.
You can see them on this link. http://www.autozone.com/in_our_stores/loan_a_tool/air_conditioning/air_conditioning.htm
Good Luck, its not that bad, especially if I can do it :lol:
The A/C clutch is about $100 new or you can buy a compressor from the junkyard with a working clutch for about $50. The puller is about $16 if you have to buy one, Autozone will rent you one for free.
The clutch hub is usually what fails, the rubber shock damper shears off from the steel hub and plate. The pulley turns, but the hub doesn't when you power up the A/C The hub comes off without much problem if you have the puller. You don’t have to do anything with the refrigerant (R12 or R134a), you can replace the clutch without draining and refilling the system. The snap ring hiding inside the hub is the only tricky part.
A few simple electrical tests are advised before popping out the wallet to buy a clutch assembly. With the engine running, use a test light connected to the 2 wires on the A/C clutch harness to make sure you have voltage when you turn the A/C on. If the system is low on refrigerant, the clutch will not engage (safety feature, keeps you from burning up the compressor due to no oil). There is an aluminum canister on the firewall with a large hose leading to the A/C compressor. There is a pressure switch on it with a 2 wire connector: pull the connector off and jumper the wires. The compressor circuit will power up, and the test light will light if the electrical circuit is good. This test is also a good way to check the compressor & clutch if the system is low on refrigerant. You can jumper the wires and the compressor will turn if the clutch is good.
