I have a 95 GT with a leaky High pressure line on the A/C. I called Ford and they want 250.00 because the high and low pressure lines are attached to the block on the back of the compressor. Advanced auto sells a motorcraft replacement that says it runs from the compressor to the condensor which is the one I need but the picture shows it without the muffler so does it have to be soldered on?? Also I heard that if the leak is in the rubber you can cut the factory crimped connections put on a new hose and use some special clamps to keep the line from blowing due to the high pressures. Anyone know anything about this please help!!!!
