A/C Problems on low mileage 04
mjbarnet
30
Iowa City
Bought an 04 Mach 1 this weekend with 1,700 miles on it. A/C worked when we looked at it (I think, but as it was fairly cold out, I'm not 100% sure), but now will blow only warm air.
When the A/C switch is turned to on, the clutch kicks in, but then it kicks right back out. This on, then off, cycle repeats every 10 seconds or so, like the A/C is trying to kick in but it never stays engaged.
I poped the hood on my 94 GT, and when the A/C swith is on, the clutch/compressor engages and stays engaged.
Any ideas what could be wrong with the 04?
Is there a fuse or a cycling switch I can check out before taking to the dealer?
The car is under warranty, but just wondering what it could be
thanks,
mitch
I had the same problem w/ my 03 Mach. Turned out to be the front seal on the compressor. The dealer can find the leak by using a dye they put in the system. Good luck.
