Hi,
Have a 5 speed with 3.73 gears. Thinking of going to 4.10's here is the reasoning.
At the track last week I ran my best time a 13.64 with a 1.91 60 at 101.48.
Went through the trap in 3rd gear at about 6200 rpm. The best I can do going thru the traps in 4th gear is a 13.8 with rpm about 4600 at the end of the quarter mile. I have 27.9" diameter X 15 " BFG DR's on the rear, the tall tires I believe are causing this. Will I dramatically change my track times if I go with 4.10's ?? They would change my trap speed for the better allowing a shift to 4th sooner ??
thread from 6-24-04 about track times.
http://forums.stangnet.com/showthread.php?t=476861
I am also thinking of a custom cam this winter but gears would be easier/quicker fix for now?? Opinions??
Still learning and practicing
TFS TW Heads, Steeda 19 Cam, Cobra Intake, FMS 65mm T/B, Pro-M 75MM MAF, Steeda 24# injectors, H&S 1.72 Roller Rockers, MSD 6al, Blaster coil, Walbro 255 LPH, High Flow Catted H-Pipe and Drag Radials (325x50x15)
Steve
Went through the trap in 3rd gear at about 6200 rpm. The best I can do going thru the traps in 4th gear is a 13.8 with rpm about 4600 at the end of the quarter mile. I have 27.9" diameter X 15 " BFG DR's on the rear, the tall tires I believe are causing this. Will I dramatically change my track times if I go with 4.10's ?? They would change my trap speed for the better allowing a shift to 4th sooner ?? thread from 6-24-04 about track times.
Steve
