A/F meter says lean.............
  • Thread starter Thread starter james51381
  • Start date Start date May 3, 2004
J
james51381
151
Newark, CA
May 3, 2004
  • May 3, 2004
hey guys, I am running at 30 psi with vacum off, is that lean? I know stock is 38. I dont have knocking or pining. Under normal driving the meter is doing its little dance, which i have heard is normal. Under deceleration the meter goes all the way lean and looks like it turn off. during WOT the meter gets to about the second or third bar on the rich bar.
I am honestly nervous about dropping the psi any lower. any suggestions would be GREATLY appreciated.
thanks in advance
james
HISSIN50
34
129
May 3, 2004
  • May 3, 2004
James, why are you running less than stock pressure?
also, i know you like your new a/f gauge, but unless it is a wideband, i would not tune with it. they are not accurate enough to use for fine tuning (if they were, dynos would be a lot less busy).
good luck.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 3, 2004
  • May 3, 2004
Hissin's right - set your pressure to 38-40 with the vacuum off, let the vacuum take it to where ever it takes it (usually around 30-32 with 18 in. of vacuum at idle), and drive on. That gauge makes a nice light show, but that's about it. The computer will take the car to very lean conditions when loads on the engine are light, that's normal -- most daily driving is in those situations. If the car's running right and you're not having significant detonation all's well.
T
thompsonsd
144
Southern Maryland
May 3, 2004
  • May 3, 2004
I agree. Unless you have a custom chip burned for other than stock pressure, run the stock pressure. I have the Autometer A/F gauge too, and when not under a load it's says I'm running lean too. I hate the way the dang bounces all over. I just wired mine with a switch for left and right bank O2 sensors, that way I'll know if one goes bad, but that's about all the attention I give it anymore.
J
james51381
151
Newark, CA
May 4, 2004
  • May 4, 2004
Thanks guys. I set it back to 38. I also did what thompson did, and used a switch for each sensor.
thanks again
james
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
  • dan50
  • Jul 18, 2026
dan50
A
Resolved 1989 Mustang bogs down after 3-5 minutes of driving.
  • Alabama
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech May 26, 2025
limp
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
