A few Questions
  • Thread starter Thread starter suki243
  • Start date Start date Sep 8, 2007
suki243
662
Southern California
Sep 8, 2007
  • Sep 8, 2007
Hey guys, I'm on the back half of finishing up the car. And I have some questions.
1. My back up lights didn't work, (which is the reason why i originally started this restoration) at first i thought it was a wire connection gone bad, but after replacing the harness, i found out that the entire back up lamp switch was gone. I was going to buy this one, http://www.mustangsplus.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=MPFMP&Product_Code=00206
But I don't know how or where to put it in. Any insight on that?
2. Battery relocation. I'm going to put the battery in the trunk. I know the cables will go back, but my question is how do I mount the box that will hold the battery? and what kinda box do i need? can I make one out of plexiglass? do they sell one at autozone? Kraigen? Do I drill into the frame rails? and do I move the starter solenoid to the back as well?
Edit: 3. Center console: any good center consoles out there? it seems like the car is missing something without one. I've seen a 65 clone shelby with one and it looks a lot better.
suki243
662
Southern California
Sep 9, 2007
  • Sep 9, 2007
also,
Does anyone know the Bulb # for the front parking/turn signals? When I was trying to replace mine, the glass part came out but not the metal base so i had to use a screw driver and plyers to completely twist, and break teh metal part out of shape so now u can't recognize the numbers on it... all i do know is that it needs 2 leads.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Sep 9, 2007
  • Sep 9, 2007
Pretty sure it is an 1157 bulb.
65fastbackresto
1,229
AR
Sep 10, 2007
  • Sep 10, 2007
I dont know about your car, but..
my neutral safety switch and the backup lights have the sending unit mounted on the transmision directly over the shift linkage on my c-4 tranny. I dont know if this applies to you or not, but it might help ya.
sburkey1967
54
Maple Valley, WA
Sep 10, 2007
  • Sep 10, 2007
They make a few relocation kits. I can't remember where I got mine from (maybe Mustangs Unlimited or Mustang Depot, but it is pretty slick. Comes with an aluminum box and you just have to mount it with allthread that comes with the kit. As for how the starter relay and wiring go, I have the same questions you do. That was going to be my next question after getting my fuel pump mounted back there.
BullittStangV8
1,104
NJ
Sep 10, 2007
  • Sep 10, 2007
summitracing.com has plenty of batery boxes. I went with their brand, the delux one I think? Its plenty nice and works fine. I did not drill through the frame, just the trunk sheet metal, with some washers on the all thread.
sixtyfive
157
  • Sep 10, 2007
Mine has a black plastic one from summit in it, and it has bolts on either side to keep it from moving
Best advice I can give you is to ALWAYS put the lid back on and tighten it down, I was having troubles with my car running one night and forgot to tighten it down, I made it about half way home and took a corner a little too fast and my battery tipped over and grounded a hole into my gas tank with the side post from the battery which ran to my msd. There were 2 loud ass pops like a gun going off in my trunk and i knew exactly what it was. I stopped instantly grabbed my fire extinguisher and popped the trunk, there was a wire on fire about 5 inches above a half a tank of gas. Needless to say a dumb mistake could of cost me my whole MSD system, or even worse, my baby could of blew up with me and my buddy in it.
geostang351
946
Danb., CT
Sep 10, 2007
  • Sep 10, 2007
65fastbackresto
1,229
AR
Sep 10, 2007
  • Sep 10, 2007
I was kinda thinking of a trunk mounted battery
But I aint now.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Sep 11, 2007
#10
  • Sep 11, 2007
  • #10
Nothing wrong with trunk mounted batteries as long as you take the precautions neccessary. I would say to have some sort of hold down on the battery regaurdless if the cover is on or off. Extra safety nets never hurt.
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 29, 2026
boatillo
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
