Progress Thread A new FB conversion for bbettto
Inner structure is welded in ,i am going to try to get the quarters on today
Here is why you test fit before you weld any thing the trunk floor drop off is not correct at the drop off to the quarter ,i have to hold a piece of metal in place and mark it on both sides so i can get it to fit the drop off and the quarter and weld it to the drop off .
The roof is done ,everything on the out side is done ,just have to weld at the bottoms of the quarters.
Passenger side gave me a bit of trouble ,the back half of the rocker has been replaced at one time and they didnt get it really straight so it didnt let me get a perfectly straight door gap ,but with a bit of door alignment it should be good to go.
I have to put in all the brackets for the interior fiberglass and back seat and all that will be left is finishing the floor
I picked up some grinding disks ,stopped by harbor freight and picked up a couple of new grinders ,always wanted one of those hand belt sanders . Also picked up a new 90* grinder ,these are made by Baxter and those two little baxters really have horse power ,way better than home depot or Lowes tools. Got most of the grinding done today and did a bit of alignment on the passenger door
Reactions: RaggedGT
Got the last two pieces of the inner door structure welded and ground the welds .
Also got the little patch in the driver side rear floor in ,tomorrow i will work on the passenger side ,it has to have a torque box top replaced so i have to cut that patch big enough to remove the top ,good thing i save these when ever i do a full floor and do not need to use them . That just leaves the front floor patches .
I finally got the top off ,i couldnt find the spot welds because of the rust ,i finally blew it out with the plasma cutter and ground the rest away ,it took 4 disks to do it !
New torque box is welded in and i wanted to make the floor patch but the torque box wore me out .
I have been working with a cracked knee cap so getting in and out of the car has been work in its self!
