A pic of my new parts.
Here is a pic of my new parts, I am almost done with my collection of parts I need to install before getting tuned in May. As of now all I need is a 3.2 Alt pulley and an 81" belt then I will be set. They are:
Hoosier 315/35/17 Drag Radials
Siemens Deka 60lb injectors with the EV6 connectors
NGK TR6 spark plugs (current ones have about 9k miles so I figured it was time for new ones)
Metco 4lb crank pulley
Billetflow 2.93 upper pulley
Bassani catted X-pipe
No, it isn't worth it to me to send it in for a Stage V port. If I want any more power I will be adding a twin screw. :D As far as fuel mods I have a BAP w/ wiring upgrade and now 60lb injectors. Here are a list of current mods:
Stiegemeier Stage IV ported blower
Stiegemeier welded and ported Throttlebody & Plenum
Billet Flow 2.76 upper
Billet Flow 100mm Idlers
Gates Belt
NGK TR6 plugs
LFP Dual pass Heat Exchanger
Diablosport MAFia
Diablosport Predator Tuner (Being replaced with SCT XCAL3)
LDC Head Cooling Mod
MM full length subframe connectors
MM caster/camber plates
Weld in Steeda IRS brackets
3/4 coil cut stock springs
Battery Relocation Kit
AMW Billet Catch Can
Dynojet Wideband Commander
Borla 14858 cat-back
K&N FIPK2 Intake
Kenne Bell BAP w/ wiring upgrade
MGW Short Shifter
UPR clutch quadrant and firewall adjuster
All polyurethane bushings (IRS, Control arms, steering rack, etc.)
Steeda IRS Brace
MM low profile IRS bolts
EGR Delete
17x9 and 17x10.5 Silver FR500 replica wheels with Goodyear F1 Gsd3's 275/40/17's front and 315/35/17's in the rear
