? about transmission removal
Are there 2 bolts that have to be taken out up on the top of the transmission like where you can barely see them.
I believe there are and I cannot get to them even with an extension and swivle because there is not enough room to break them loose. And I have no room from the top because I have the bullitt style intake manifold and it is a squeeze.
Any tips on how to get these things out:mad:
Dope 97GT said:
this sucks my haynes manual said nothing about the 2 bolts on top and only about the 5 on the sides if I knew I had to take them out I woulda took it to a shop.:notnice:
I made the same assumpsion. I had to get a friend with smaller hands than mine to get in there. I tried and just couldn't squeeze in there. You can see them if you get a flashlight and look in the tiny space between the firewall and the intake.
Yup, take the x-member out and lower the tail end of the tranny down. Then use long extensions and a swivel. The trans will drop down far enough for you to have a straight shot
Ohhh them 2 bolts from hell on top of trans...
Tomstng and I had good ol' time with them o both of our car...
Do the search. There are several thread related to that bolts...
Seems like its either come out easy, or gonna fight to the death. Mine fought until death(After fighting with it for 2 days, and broke ever swible and 2 extension, I pulled grinder, and grinded it off
i did like 5 searches with different themes and finally came across the threads even yours lol.
I think i am gonna pic up a 13mm swivle socket instead of a universal one and try that.
Do you think I can jack up the engine some by the oil pan without crushing it...maybe only like an inch or so.
I did that to get grinder in. But you should be able to get socket in by just dropping tailshaft down.
there were thread about month ago or so who was in same situation as you are. I can't locate that thread....
The swivel socket would work good... I dont use standard universal joints, I use impact swivels.. they are built alot better and dont kink when your in your situation..
I rounded the last bolt off soo much that it will not come off even now that I have almost a straight shot to it.
I dont think I am going to be able to get a grinder or anything in their either to get it out.
What is a way to get a rounded bolt out?
Always the last damn bolt on everything I do.
my mechanic down the street had like a spiral socket that needed to be pounded on and that finally got the last bolt out...now I have to get new ones from ford because they are so messed up:nonono:
But now I am having problems getting the transmission off the engine. I have it level with my jack but with the weight of the jack and the tranny it will not slide back. I tried to just get in there and muscle it off but I have had no luck.
So now I am stuck with not being able to take the tranny off so I am taking a break. Someone to help me would be nice.:(
you dont need a jack.. just crawl under there and put your knees up on the tailshaft and put your hands on the bellhousing and pull the bastard back... also it might not be comming off because your shifter might be hitting the body.. just pull it down and out..
Just dont smash your balls like i did last week when i was doing my clutch..
