ABS delete pics
i deleted my abs awhile back and ever since i did i have given many of u guys the info through pm's, so i figured i would share the pics and info for the rest of you since this seems to be coming up alot lately. i deleted mine to clean up the engine bay and i never drive my car in the rain. once deleted the bulb will not come on. a few things to know:
-i didn't have to buy any additional line, there was more than enough left over when i was done
-i spent about $5 in fittings (a 3/16th tee, a few 3/16th tubing nuts, and a union)
-this was very time consuming
-requires the use of a double flaring tool. i'm not that great at using it so it took me some time and practice to get the flares right
now the pics. in the first pic u can see the tee i put in. the line coming out of the bottom port of the tee goes to the l/f wheel. the other line comes out and is run like factory, down under the radiator, to the union u see in the second pic, and then to the r/f wheel. the line for the rear brakes comes out of the proportioning valve, and i ran it down the drivers side of the car to the rear, where it tees off to each rear caliper.
You know, young man, the ABS system was designed to be there for a reason and is there for the safety of you and others on the road. Disabiling the system means you are a menace to yourself and everyone around you and could potentially take out some bitch-a$$ in an M3 (or M5) on the Northern State. Ha Ha. :LOL:
Tnx for the pics dude, keep up the good work and CLEAN engine bay...
