- May 4, 2007
- 0
- 0
- 0
I am planning on replacing my AC compressor FINALLY. It has been ratteling like a paint can for several months now. It looks like a pretty straight forward job.... 3 bolts holding the compressor in and 2 lines hooked to it I think. I have called around today and found out its going to cost me roughly 100 bux to have the system evacuated and then recharged. I am planning on going ahead and replacing the oriface (sp?) tube also while I have the system apart. The reason im only doing that is cuz its cheap and the compressor itself (as it sits now) is still good. Its just the clutch is gone on it.
Ok so my question is this.... Does anyone have a Haynes manual to refer to or know how much oil Im sposed to use in the compressor when I install it? It seems I have read on the net somewhere that it only takes an ounce or 2. I checked with AZ today and they say 8.5 ounces.
Any other tips or tricks to this job is welcome too BTW!
__________________
__________________
find a mechanic or someone who works in HVAC to lend you their tools for an hour or something. I've been doing that same process for years with my dad with commercial and residential HVAC.
if you do manage to borrow that stuff, just suck the lines clean with the vacuum, then pressurize slowly with the gas
