  • 1994 - 1995 Specific Tech
ac compressor
  • Thread starter Thread starter will_95gt
  • Start date Start date Jun 30, 2007
will_95gt
298
Austin, TX
Jun 30, 2007
  • Jun 30, 2007
Ok, so all the shops are telling me if they replace the ac compressor they also have to replace the dryer and something else in order to get a warranty.
My question is, are they just saying that to make more money? Could i just tell them to replace "just" the ac compressor and then don't worry about any warranty?
thanks
-will
will_95gt
298
Austin, TX
Jun 30, 2007
  • Jun 30, 2007
btw if my ac compressor drags on the belt whenever i have it on then that means the ac compressor is messed up but the clutch itself is fine right?
HISSIN50
34
129
Jun 30, 2007
  • Jun 30, 2007
They are concerned with system contamination. A flush of the system should be performed anyhow but in the Auto business, you try to do it halfway decently the first time so the car isnt a comeback.
If I went as far as having a shop do the work, I'd let them replace the other stuff (within reason, logically and financially) because contamination is a real concern.
You might want to touch base with Danny (Wytstang). IIRC he just had his system gone through and some stuff replaced. He might have some insight from the shop's perspective.
Good luck.
steede302
75
jacksonville fl
Jul 2, 2007
  • Jul 2, 2007
I just did my ac. I bought the parts from napa and installed them myself( compressor, dryer, upper line kit and orafice tube), then took it to an ac shop to have the condensor and evaporator flushed in order to get the warrenty from napa. I had 3 ac shops give me prices from $1080 to $1200. Did the wrench turning myself and spent a little over $650 total parts and labor (for the flush and ac charge). ICE COLD every since.
95BLKGT5.0
608
Auburn Washington
Jul 2, 2007
  • Jul 2, 2007
If you don't replace everything in order to get a warranty then you will just be replacing everything again next year including the comressor.
JUST DO IT
Don't cheap out
will_95gt
298
Austin, TX
Jul 6, 2007
  • Jul 6, 2007
JUST DO IT
Don't cheap out
dang!!! i was counting on "cheaping out" because i can't afford to do it right, lol. I would if I didn't just have my power steering pump and rack and pinion replaced
I guess i'll just have to wait till i have some extra cash.
thanks guys,
-will
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 6, 2007
  • Jul 6, 2007
JUST DO IT
Don't cheap out
I disagree. You need to know the cause of the compressor failure in order to make that determination. I replaced nothing but the compressor. Guess what? Two years later, still as good as new. Just some nice, ice cold AC.
C
chuck943
262
north carolina
Jul 6, 2007
  • Jul 6, 2007
you might get by with it as Matt has but the reason u replace the dryer and orffice tube is because the dryer has a desicant bag in it that is there to trap moisture and the orffice tube has a small filter on it also. If system has been open or has a leak then moisture can get in the system and it is only so much that the filters can handle. If too much gets in the system it will disrupt the oil flow thru the system which could cause alot of damage. The oil is carried thru the system by the freon.
Plus if the compressor actually has damage the metal from compressor could get all thru the system.
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
A
Strange AC issue
  • Adanesahde
  • May 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 3, 2025
Mcmahst
G
2005 Mustang GT AC cycling on and off every minute
  • GeorgeSwadling
  • Jul 12, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 12, 2025
GeorgeSwadling
G
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Gen 3 Coyote Swap Variable Displacement AC Compressor Troubleshooting
  • rydnoryder
  • Jun 12, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jun 16, 2025
rydnoryder
