Accel ignition swap
  • Thread starter Thread starter bluegt500kr
  • Start date Start date Jan 26, 2013
bluegt500kr
37
Alabama
Jan 26, 2013
  • Jan 26, 2013
I'm about to swap from points to an Accel XRi setup. As usual my stuff has a twist or two. My 302 has an Edelbrock coil which has a white plastic connector that attaches the wires to the coil. Also, there is currently only one wire coming from distributor. It is spliced into another wire running to the terminal on the coil that is unmarked. The other terminal on the coil is marked BATT. If I keep this coil, which wire will go to the BATT side? The car runs fine so I don't really want to replace coil but should I?
Thanks for any help.
rbohm
6,698
550
204
tucson,az
Jan 26, 2013
  • Jan 26, 2013
the power wire goes to the batt side of the coil. as for replacing the coil, you dont need to, but to get the best performance from your new ignition, i would go with the blaster lll coil.
bluegt500kr
37
Alabama
Jan 26, 2013
  • Jan 26, 2013
Thanks for the info. In the instructions it also states that I need 3-4 ohms resistance in my coil. My current one has only 1.5. If I change to a blaster III will that work without adding any external resistor?
rbohm
6,698
550
204
tucson,az
Jan 26, 2013
  • Jan 26, 2013
if the blaster lll comes with a ballast resistor, then you need to install it. mine did come with a ballast resistor. its easy enough to wire in though.
bluegt500kr
37
Alabama
Jan 26, 2013
  • Jan 26, 2013
Thanks, rbohm
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Rally-Pac Wiring
  • Sparksteam
  • Oct 14, 2025
1965 - 1973 Classic Mustangs -General/Talk- Oct 15, 2025
Sparksteam
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
