Accufab 75mm tbody and tps fitment
DeathProof88
99
34
28
PA
So I'm trying to finish my build up with this accufab 75mm throttle body. I screwed the motorcraft tps down and it pushes the throttle blade shaft causing it bind! I don't see a gasket online anywhere... what am I doing wrong here? Can I simply add thin washers? Thanks in advance.
Post #7:
Reactions: DeathProof88
Post #7:
You gave me an idea. I had an extra iac gasket that fit the center of tps perfectly, so I made a gasket out of it.
