  • SN95 4.6L Mustang Tech
Accufab plenum and 70 mmTB installed yesterday
  • Thread starter Thread starter Satin Silver GT
  • Start date Start date Apr 16, 2004
First Prev 2 of 2
Go HoTO!
602
Mountaintop, PA
Apr 18, 2004
#21
  • Apr 18, 2004
  • #21
Read all about them HERE:
http://forums.modulardepot.com/showthread.php?s=&threadid=20529
R
rodent79
21
#22
  • Apr 19, 2004
  • #22
stimmler said:
You can get the tb/plenum combo for about 440. I am still using my K&N drop in filter until i have enough to upgrade to a densecharger. I am not sure if you can use the same inlet tubing if you use the 75mm tb, it was a tight fit (PITA) on my 70mm.
The inlet tubing fits the 75mm if you shave the inner lip as I did. Worked out fine.
Though a week later I got a new C&L trueflow fit perfect for 106 shipped.
parkway ford on ebay.
O
ONZZ
238
Hawaii
Apr 19, 2004
#23
  • Apr 19, 2004
  • #23
very nice gains
00VERT GT
376
SW Florida
Apr 19, 2004
#24
  • Apr 19, 2004
  • #24
wms004 said:
with the dragon and 75mm.. no low end loss. It did loose some low end in hp and tq with the 70mm.
(from modulardepot)
-wade
that is for the Dragon only the accufab gained down low with the matching 70mm tb.
pony_vert02
285
AUSTIN,TX
Apr 19, 2004
#25
  • Apr 19, 2004
  • #25
The 75mm will fit as well, as this is the setup that I have..but you're right.. it's a BIG PITA...very tight fit...I used a little soapy water and opened the screw in clamp as far as it would go... eventually it slipped on...
stimmler
248
Japan
Apr 19, 2004
#26
  • Apr 19, 2004
  • #26
WD-40 baby. Put a little on my finger and ran it around the lip.
GreekStang85
485
#27
  • Apr 19, 2004
  • #27
so if you are going to stay n/a then it is better to get a 70mm TB than a 75mm TB??
03trubluGT
1,067
Mansfield, TX
Apr 19, 2004
#28
  • Apr 19, 2004
  • #28
6 in one hand or 1/2 dozen in the other.. I don't think it makes much difference.
I stayed with the 75mm after the testing becuase the car made more total HP with it on. I may go Vortech someday, and that was another reason to keep the 75mm TB.
Matt
GreekStang85
485
#29
  • Apr 19, 2004
  • #29
now i have a dillema with the 70mm and the 75mm
stimmler
248
Japan
Apr 19, 2004
#30
  • Apr 19, 2004
  • #30
Yes this is what I have heard. Mildly modded= 70, More modded 75. Some choose to go with the 75 anyway mildly modded and suffer some low end torque loss compared to a 70mm until they get more mods. Check out Matt's plenum test on modulardepot and you can see the dynos for each combo. Keep in mind that Matt has a 2003 Mustang GT and has BBK Long Tube Headers, BBK X Pipe, Magnaflow Catback. Where as I only have a borla cat back and a 98 mustang gt. So my numbers would most likely not be as good with a 75mm as his. If I had LT's and an Xpipe I might have gone with the 75.
If I supercharge I will definately go 75,
pony_vert02
285
AUSTIN,TX
Apr 19, 2004
#31
  • Apr 19, 2004
  • #31
Matt
EXACTO-MUNDO! I AM PLANNING ON GETTING A PRO-CHARGER...SO, I OPTED FOR THE 75MM T/B & PLENUM..
stimmler
248
Japan
Apr 19, 2004
#32
  • Apr 19, 2004
  • #32
PS Thanks To Matt for all your work in testing those tb and plenum combos. Made my decision a lot easier.
GreekStang85
485
#33
  • Apr 19, 2004
  • #33
im staying n/a and planning to go heads, and cams in the future so i might go for the 75mm TB
slvrbullIT
635
Dallas, TX
Apr 19, 2004
#34
  • Apr 19, 2004
  • #34
i just ordered my 70mm accufab throttle body!! im getting the plenum next week too.
wms004
2,864
Los Angeles
Apr 19, 2004
#35
  • Apr 19, 2004
  • #35
I'm perfectly aware. I was just refuting his statement that 75mm t/b's make you loose low end torque with aftermarket plenums. If i were to buy the accufab plenum I'd probably get the 70mm t/b too.
-wade
First Prev 2 of 2
Accufab plenum and 70m TB installed today
  • Satin Silver GT
  • Apr 15, 2004
  • Regional Forums and Event Information
Regional Forums and Event Information Apr 16, 2004
98GTX
9
Accufab 75mm TB/Plenum Install Write-up (Biggest DUW Ever)
  • helty
  • Jan 29, 2006
  • 2 3
17K
SN95 4.6L Mustang Tech May 1, 2008
SROBERTLAW2003
Dynoed Tune Today Puzzled By Numbers
  • Pearl02
  • Jul 28, 2005
SN95 4.6L Mustang Tech Jul 30, 2005
Orions98GT
oem block na 320/324 combo & more
  • final5-0
  • May 25, 2007
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 25, 2007
final5-0
Before & after Dyno result: Accufab 70mm Throttle body & Plenum install on my car !
  • mpcv2000
  • Aug 5, 2004
9K
SN95 4.6L Mustang Tech Aug 7, 2004
stimmler
