Curse you helty! It seems you can't just reuse the stock IAC bolts for the accufab plenum. Do brand new accufab plenums come with new bolts for the IAC? We can't get the bolt all the way in! It's almost like the hole isn't tapped enough!!
helty said:Ambo, Im sorry you're having problems. I swear to you I used all stock hardware, and everything went together like it was OEM. Hell the IAC was the least of any problems I encountered, it was the rear EGR bolt that was a bitch. Didnt want to go through the new gasket.
Is there any chance theres a difference in bolts from a 2000 model to an 02?
Keep the faith man, projects of this nature tend to take a lot out of you bc you're looking forward to the end result and little things keep putting it off. I know this bc Ive dropped 2 K-members in as many weekends. Keep the faith. The Boost is worth the wait
Good luck with it.
I just got a new TPS sensor when I put mine in too. Cost $25 and saved me a headache. This was my first real install (besides the shifter), did it last weekend and was surprised that I had no problems with it.AmBo said:After much stress we finally got everything on the accufab. Just needed some washers to get the thing done. The next big PITA was the TPS screws. Those things were HORRIBLE!![]()
shhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!timeless2 said:helty = scammer
Cat's outta the bag.helty said:shhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!
i still have parts to sell![]()
Stang|ess said:Helty promised he's gonna run away with me, and treat me like a princess. All I got was crabs, and a wicked case of herpes.
