Accufab TB/Plenum
ShapeShifter
85
alrite guys not so long ago i purchased an Accufab TB/Plenum combo, the TB was 75mm...and the problem im having is after a buddy and i installed it my car seems to hesitate(bogs?) for a sec and then takeoff...so i thought maybe i needed a tune, so i already had a Tuner so i finally tuned it and problem is still there...ok,so i thought the throttle body was too large for my N/A car with minimal mods,i.e....Exhaust,CAI,Tune,TB/Plenum...so i swapped out the 75mm throttle body for a 70mm one...im still having the same problem just not as bad...what could be wrong?....
Could it be that, with the increased air flow, you're now running a tad lean? When you stomp on the accelerator, you're seeing a delay as the fuel system tries to catch up?
I noticed a little of that, too, when I put in my BBK 75mm. I used my SCT to tweak things a bit, but I think there might be some more adjustment needed.
you should have been fine with the 75mm. The only thing I can think of is you left one of the tubes loose. You may also have a leak in the main air tube.
Another thing is... did you disconnect the battery for a decent ammount of time? If not do this, the computer could be confused with the new air flow.
bgrd351 said:
you may have to reset the PCM so it can relearn the TPS setting
I knew I forgot something, get a vol-meter or go to autozone or something and have them check the volatage on the TPS, should be .98-.99 I believe
yep, i punch it and it delays for like a tad sec and then goes....
