Muratic acic. You can get it a Rural King. It is dangerous.The vapers can kill you. Hast to be done in the wide open away from your house. I thought about doing it in the middle of my yard with a trash can turned over on top of it to see if it contained it. The vaper will actually burn your throat and lungs. Be safe!
hey,I'm out of a job at moment and got alot of time on my hands. I'll extrude hone your lower and match the upper. It will all be ported/polished to a professional grade. save you the fatal fumes.Just send me the gaskets you want to use.
let me know....
Kevin
No you are correct I thoguht he working with EFI. If he workin EH I can still do some good work. For anyone out there if they want a mirror finish port job it can be done. I won't charge to much since i know some of you guys on a tight budget.
I was thinking of giving this a try sometime in the near future but with all the right precautions being taken, i was going to atempt this on the upper and lower intake that i got @ the autowreakers, when doing the porting how long should this solution sit in the cast , or does it even work with cast. I belive that the upper intake is made of cast, correct me if im wrong.
