The clutch cable in my '88 GT is sticking badly and needs replacement. I'm going to buy one of the adjustable cable & quadrant kit's . . . does anyone have any experience with the lesser-expensive kits that Summit and Jegs put their names on?
with all due respect, I disagree once again.
> snip...
The following picture is a ford racing quadrant (blue one on bottom) followed by a MM quadrant in the middle, followed by the fiore piece up top. You can see how the fiore and MM quadrant have a much shorter hook, and will be compliant with your firewall adjuster.
On the other hand, that blue frpp piece is the same as the bbk(grip) piece, and many others. Because it is longer, the cable grabs MUCH further back and therefore is incompatible with firewall adjusters.
please do, as this is very good info for me to see. As you can see in the above pictures...the difference isn't a whole lot. I suppose it may just be enough though. Let me know how it turns out..Jeremy
mark, now that you mention this, you may be ok.
the t/o bearing is designed to have constant pressure on it. It's called preload. This is meant to be this way, and is in the ford service manuals.
the best way to adjust it is to tighten it enough so that it grabs an inch or two or more off the floor, but before halfway in it's travel.
also, so long as you can depress the clutch pedal a little before you feel the clutch actually begin to disenage, you are ok.
pressure is fine, so long as the pp isn't always disenaging with the foot off the clutch.
>snip
One more thing worth noting...on the lethal performance web site, it says 94+ on the fiore fwa's and quadrants. they will work with a fox, it's all the same stuff. The one exception is that his quadrant doesn't have a slot cut out to get past that plate on the pedals. For this reason, I'd suggest the MM single hook quadrant with the fiore fwa.
>snip
