Ok I know it probably depends on the manufacturer but here goes... these are Tr1ck One (Dugan Racing, GA). and I would like to know the range of negative camber and also positive caster available. Perhaps the plates don't make a difference provided they allow the full range given in the strut tower holes. But I'd love to know what i'm working with so I can get something appropriate and not too ridiculous for tire wear.
BTW the car hangs beautifully, it's a very obvious change but I can't always drive on curvy roads. However, I almost never get on the hwy. I just go backroads between work and don't put a ton of miles on the car to begin with.
Plates:
Different views:
Sorry the car is dirty..
Thanks for any help you may be able to give me... btw, usually the rear wheels look like they have a slight negative camber before doing this to the front.
Here is an older pic of the rear without adjustments to the front and different tires. I know I'm parked with my wheel turned which easily makes up for well more than half of the look here but it usually looked like it did have a slight negative camber in the rear if that's even possible.
Plates:
Different views:
Tires wear fine, at least as fast as I go through them haha.
