Adjusting the Clutch Cable?
  • Thread starter Thread starter Black Sun 5.0
  • Start date Start date Aug 23, 2005
Black Sun 5.0
1,337
L.I., N.Y.
Aug 23, 2005
  • Aug 23, 2005
I just installed my new MGW shifter and I appear to be getting a bit of grinding, mostly when going into second and definitely third gear. I just had a clutch cable installed about 3 weeks ago and was thinking it may need to be adjusted. How is this done?
89lxsport50
550
Franklin Tennessee
Aug 23, 2005
  • Aug 23, 2005
If you have the stock quadrant, pull up on the pedal with your foot, then push it in to the floor. It may take a few times for it to get adjusted. If you have an aftermarket quadrant and firewall adjuster, you adjust it by turning the firewall adjuster in or out. I don't know if it will solve your grinding problem, but it is worth a try.
Black Sun 5.0
1,337
L.I., N.Y.
Aug 23, 2005
  • Aug 23, 2005
It almost seems as though the clutch isn't engaging properly. Mid shift it give a quick grind (and burnt clutch odor) then goes into gear.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Aug 23, 2005
  • Aug 23, 2005
Without the car running: Try shifting with the clutch pushed in. If you have problems shifting without the car running then it is the clutch.
Adjust it as described above.
If you can shift with the car off you most likely have a transmission that has syncro's that are going bad.
Black Sun 5.0
1,337
L.I., N.Y.
Aug 23, 2005
  • Aug 23, 2005
I assume if that's the case it's time for a new tranny? I'm just wondering why this appeared immediately after replacing the old shifter.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Aug 23, 2005
  • Aug 23, 2005
Did your new shifter come with stops on the base? Did you adjust them ( I am sure you did, but I have to ask for the sake of clarity)
If the syncro's start to go, the car is still driveable, but you will need to start saving up for a tranny.
Black Sun 5.0
1,337
L.I., N.Y.
Aug 23, 2005
  • Aug 23, 2005
If what the car is doing is the synchros, it's not driveable. I'll have no clutch in about a week. Yes, the stops were set correctly, but this really shouldn't interfere as long as they're not too close to the shifter.
HISSIN50
34
129
Aug 23, 2005
  • Aug 23, 2005
How was the clutch's freeplay?
Did the new shifter get the plastic cup transfered onto the throw-rod?
Good luck.
Black Sun 5.0
1,337
L.I., N.Y.
Aug 23, 2005
  • Aug 23, 2005
Yes, I did move the cup over with the new shifter. But on a funny note, it MAY have just been my driving. I just had the car out after adjusting the clutch a few times. I took my time with the shifts and it wasn't giving me a problem. Something tells me I'm just not used to the shorter shift when compared to the stocker. Time will tell.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
