adjusting the parking brake
  • Thread starter Thread starter zzyzx
  • Start date Start date Dec 11, 2009
Z
zzyzx
34
California
Dec 11, 2009
  • Dec 11, 2009
I need to adjust the parking brake on my '89 V8. The Haynes manual shows the adjusting nut being in front of the parking brake lever inside the car. I just took off the center console, but I don't see that nut. Is Haynes incorrect? Is the parking brake supposed to be adjusted from a different location? Underneath the car?
Aryan15
236
CA
Dec 12, 2009
  • Dec 12, 2009
The parking brake should automatically adjust itself everytime you apply the brakes in reverse.
Z
zzyzx
34
California
Dec 12, 2009
  • Dec 12, 2009
If I pull the parking brake all the way, it doesn't fully applying the brakes. Could I have put something back incorrectly when I replaced the shoes? The brakes seem to work perfectly otherwise.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Dec 12, 2009
  • Dec 12, 2009
its a parking brake, not a drift brake, they arent ment to be able to lock up the rears just keep the car steady when its in park
Z
zzyzx
34
California
Dec 12, 2009
  • Dec 12, 2009
LOL, yeah, but it doesn't even lock them up enough to keep the car from rolling down a slight incline. In my manual it says there's a way to adjust them, and it shows an adjustment nut located in front of the parking brake lever. I couldn't see it when I took off the center console. (I have an '89 V8)/
Mustang5L5
Mod Dude
Feb 18, 2001
43,333
18,059
224
Massachusetts
Dec 12, 2009
  • Dec 12, 2009
I believe the adjustment is made inside the drum itself. I beleive there is a small adjuster wheel you turn to spread the shoes slightly more.
Unfortunately, i don't know. My only experience with drums was when i tossed them in the trash and put disks on
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Dec 12, 2009
  • Dec 12, 2009
Required Mod from the factory, pretty sure its in the manual somewhere too...
stang&2Birds
2,091
New England. :-) CT/MA
Dec 12, 2009
  • Dec 12, 2009
Geez, a simple question. You'd think someone would know.
Well, I do, kinda.
The diagram that you're seeing is for a pre-87 Stang. I should know, I have an '86.
For 87-93, the parking brake handle has a spring that should keep tension on the brake cable. Also, as people have said, the star wheel adjuster in the drums must be working and have the correct adjustment.
With the above said, there's an equalizer right below the parking brake handle that transfers the force from the single cable from the handle to the two cables that go to the back wheels. There is often the ability to have an adjustment there. I do not know how that equalizer bracket and cable changed over the 87-93 years. However, I do know that a many years ago, a Fox Stang that I found in the junk yard had an "adjustment nut" on the cable that went from the brake handle to the equalizer. If it was really an adjustment nut, or if there was juts a long section of threaded rod at the end of the single cable, I can't say for sure. What I know is that the Fox that I took the equalizer bracket from didn't have the equalizer bracket all the way back on the threaded rod section.
Also, for a properly adjusted and working parking brake system, with stock size and type tires (width and not race tires), basically any car should be able to lock up the rear tires with the parking brake at speeds under ~5mph. Most will do it up to 10mph.
So, you have a number of things to check, and that could be wrong.
Good Luck!
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
Dec 12, 2009
  • Dec 12, 2009
Well, I do, kinda.
Good Luck!
The Threaded Center Cable you came across is the one that Ford puts in with the M-2300-K Kit. The adjustment on the stock cars is in the drums and is does a pretty lame job of holding the car.
Z
zzyzx
34
California
Dec 13, 2009
#10
  • Dec 13, 2009
  • #10
What adjustment is there in the drums? Do you mean the star wheel? If I adjust that, I would just be getting the shoes on too tight at all times, right? Is there a way to adjust only the parking brake at the drums?
spoolinfusion
#11
  • Dec 13, 2009
  • #11
negative, they use the same adjuster. i would adjust them out more. make them click until you can spin the wheel and have it stop itself after about 1.5-2 revolutions.
I take it they were fine until u replaced your shoes?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
Dec 14, 2009
#12
  • Dec 14, 2009
  • #12
The starwheel is the only adjustment, remember how old these cars are getting, it may be wise to replace the cables as the stretch over time.
Z
zzyzx
34
California
Dec 14, 2009
#13
  • Dec 14, 2009
  • #13
Thanks for all your help, guys!
P
Rear disk brake caliper parking brake adjustment
  • parrotguy
  • Oct 23, 2025
1974 - 1978 Mustang II Talk & Tech Oct 24, 2025
2Blue2
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
General karthief
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
