advance or retard the cam?
SPEED FREAK
1,448
Regina, SK.
I have the comp cams version of the "e-cam" in a hydraulic flat tappet form to fit my 351w. My issue with it is the erratic idle. I have set the idle higher to compensate but to no avail, the idle tends to do as it pleases. My question to you is since i have the option on my timing gear to advance or retard the cam by 4* would this be worth the hassle? which would net the calmest results? I realize that this may be one of those questions that would be more application specific, but I have always been under the impression that advancing the cam will subdue it a bit. Am I wrong?
I supose I should mention that the engine is fuel infected and retains the stock eec 4 procesor with no modifications to the computer itself. I do not mind the lopey idle so much, just that it is not consistant at all and therefore sounds pretty crappy.
did you dial in the cam in the first place so you know where you are starting at? "straight up" doesnt always mean 0*, if so i would never recommend retarding a cam, i would how ever recommend advancing it 2-4* depending on clearance.
