Advancing the cam?
  • Thread starter Thread starter TheTacoWarrior
  • Start date Start date Feb 17, 2006
T
TheTacoWarrior
14
Pollock Pines, CA
Feb 17, 2006
  • Feb 17, 2006
I've heard that advancing the stock cam 2-4 degrees can help get rid of the lag that 5-0's have in the lower end. Has anybody done this/ does anybody know if it's true? Does it kill the top end or does it still pull to the redline? Thanks for your help guys.
wild86stang
115
Milan, OH
Feb 17, 2006
  • Feb 17, 2006
Advancing a cam moves the powerband towards the low end. Yes, it's true and yes it will move the power away from the redline.
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Feb 17, 2006
  • Feb 17, 2006
From a straight up installation, advancing the cam 4 degrees will move your powerband down by about 200 RPM.
I
IntenseBlue
946
  • Feb 17, 2006
What about below that?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 19, 2006
  • Feb 19, 2006
its a good idea i mean better to make your power at a lower rpm then always haing to have the engine screaming.
T
TheTacoWarrior
14
Pollock Pines, CA
Feb 21, 2006
  • Feb 21, 2006
Thanks for the advice guys. I guess the best way is to find it and see if I like it huh?
thumper460
3,022
Orange Park , Fl
Feb 21, 2006
  • Feb 21, 2006
"You were right, the B cam, advanced 2 degrees on 1.7 RR's was the way to go. 1st of all the idol is mean, sounds much meaner than even bigger cams. I'm kind of getting sick of people always asking me "what's in that thing". 2nd of all low end tq is also good. Mine is a daily driver, can't afford too much bottom end loss. True, it's choppy under 1800rpm, but once after 2500rpm it's alive. I can do 2nd gear starts even on slight inclines... "
Advancing the Cam !!
ya i first had it installed straight up first. But then pulled it all apart and put to 4degrees advance....WOW a world of a differance. all my stang buddys pulled theres apart to and did the same.
12.69 @ 105 mph " !!
Here are a few guys the bumped the cam up!! It works!! and it has always been the way to TUNE the camshaft!! cool??
Just me..............................
Thumper
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
