Slow5.0
I ported my intake before i installed two years ago, so i couldn't say there is improvement because i never run this intake stock
zenboy99 said:Have Total Engine Airflow or Fox Lake take care of those Twisted Wedge heads for you. They can make them flow well over 300cfm. Then maybe the Edelbrock Vic EFI intake and a custom cam.
Thats my dream set up down the road. Ported TW's, victor 5.0 manifold, 90mm tb, a REAL collector on my bbk longtubes, a 3" mid pipe and shift at 7,000 with 4.30 gears wytstang said:The cobra intake is not a "huge" restriction. Tmoss has posted dyno result from a 347 running a ported lower cobra against a Holley intake and the cobra was right there up until 6500 rpm I believe. That was the only changes that were made (intake swap comparison) pm tmoss for the sheet. So Pops Fun I agree with your son, BTW that 347 was N/A.
Impressive a "stock" cobra could hang with the holley, thanks for posting the dyno prooftmoss said:Actually the Cobra intake was STOCK! I WISH I could have worked that lower before the test!!!!!!!!
Slow5.0 said:Can you tell me which one is GT-40 or whats peek HP and TQ on GT-40 on that dyno sheet
Thanks
tmoss said:It just occured to me that you be referring to the dyno test of one of my Explorer intakes that got replaced by an RPMII - which I bested..........but it went to 6,000 rpm.
wytstang said:Impressive a "stock" cobra could hang with the holley, thanks for posting the dyno proof![]()
ARMAGEDON said:Check my sig an mirror my intake track from K&N to lower intake. Plus add 30 lbs. injectors. Recalibrate chip. That is your bottle neck. Then if you want a little extra insurance. Add a 75hp N2O kit.
zenboy99 said:To me it doesn't seem like the Cobra's hanging with the Holley after 5500.
Grn92LX said:Why did he put an rpm II manifold with an E cam?![]()
