AEM's Other Side
  • Thread starter Thread starter 4Jenna
  • Start date Start date Feb 12, 2010
  • 3
First Prev 2 of 3 Next Last
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Feb 13, 2010
#21
  • Feb 13, 2010
  • #21
Cool. Sorry to hear about the bs you went thru. Customer service is so easy....yet so many companies forget to take care of it. They must be hurting for $, but this is gonna hurt them even more in the long run.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 13, 2010
#22
  • Feb 13, 2010
  • #22
Chris, post a link to the thread over here on SN. They can't delete this one.
4Jenna
4,326
AZ
Feb 13, 2010
#23
  • Feb 13, 2010
  • #23
post is gone again off of AEMs forums
Over 200 views in one day
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Feb 13, 2010
#24
  • Feb 13, 2010
  • #24
Got a copy? We'll stick it in the feedback area here.
4Jenna
4,326
AZ
Feb 13, 2010
#25
  • Feb 13, 2010
  • #25
AEM's Other Side - Corral Forums
4Jenna
4,326
AZ
Feb 13, 2010
#26
  • Feb 13, 2010
  • #26
No i made no copies of the AEM forums. I made the same post, but it was the post from others that counted.
I am done posting their, they will never let that stay up.
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Feb 13, 2010
#27
  • Feb 13, 2010
  • #27
Well, it will stay up here. I'm all for educating the public.
BlownFiveLiter
18
108
Chicagoland
Feb 13, 2010
#28
  • Feb 13, 2010
  • #28
Wow, WTF did Corral do to their layout? I thought it was busy before, but with the new skin and differing sizes to the links/text, they just pretty much assured that I won't post over there at all now. It's not like I did much to begin with, but damn...
Edit: I'm stupid and don't read notices. They're working on the issues...
R
racewerks
#29
  • Feb 14, 2010
  • #29
I would like to stand at Chris's side on this situation. I am the person that did the install of the COP setup. I am a wiring guy for a living and that is what I know I don't claim to no everything but I know what I know. First of all every attempt was made on our behalf to double and triple check everything. Every wire was soldered and infact from the computer to the coil on cylinder number 7 when I ohm'ed that the resistance was so minimal it was like .002. Now with that being said I can't believe that AEm had me cut the wire coming out of pin 24 I believe was the pin 2 inches above where the pin went in in the stock harness. With that minimal resistance there is NO way that the voltage would have gone from 5v to 1v. I spent 6 hours of my labor at $65.00/hr at no charge on Chris's behalf to exhaust every effort to get the COP to work. I have been professionally wiring and plumbing racecars for 19 months and I was blown away by the events that have taken place. It is unfortunate that these events have taken place and with the customers best interest in mind we have removed the AEM, EPM, COP and have gone to a new MSD Ignition Setup and a Big Stuff 3. I wanted this to work for Chris as badly as he did and we inspected the board ourselves check the jumper on JPC3 and infact even swapped the Jumper from JPC1 (a coil set that we knew was working) with the Jumper on JPC3 and still the same problem. I then ohm'ed every wire in the install that I did and the grounds were grounded to a ground stud on the cage in the car that we installed to ensure proper grounding. The power wire was also soldered and installed. At no point in time was the battery ever hooked up while any functions or work being performed of the install were done. The emails that I received stated that they said that it was a power or ground issue or that 2 pins were touched together. My converstaion with AEM just stated to me that the board was bad and that there are 2 different models and depending on what board it was the total to fix it would be between $400.00 to $500.00. I am not on here to keep the pot brewing just want people to know the facts. If an AEM representitive would like to call me and discuss this with me the one who did all the work and point fingers I invite you to call us from 9am to 6pm Arizona time and I will be happy to talk to you. I find it in no way right that a post was deleted or hidden and I believe that there needs to be a resolution to this issue. What this car means is priceless and for a company that is suppose to have a reputable name there were alot of things that were gone wrong from day one and the facts that were stated above would leaving anyone sour and feeling like they get bent over and f**ked hard.
Respectfully,
Robert Green - Owner
RaceWerks Wire Shop
T
turbogt
723
Montana
Feb 14, 2010
#30
  • Feb 14, 2010
  • #30
Strike said:
In light of corral's decision to delete your thread in an attempt to inform the public, I think I will add this thread as a sticky for a bit.
The thread has been undeleted but moved in the Corral forums.. It still shows up in the AEM section, but says moved..
YEAHLOH95
1,249
EVERETT,PA
Feb 14, 2010
#31
  • Feb 14, 2010
  • #31
that sucks no aem for me
T
turbogt
723
Montana
Feb 14, 2010
#32
  • Feb 14, 2010
  • #32
and now its closed.....
4Jenna
4,326
AZ
Feb 15, 2010
#33
  • Feb 15, 2010
  • #33
LOL, shutting me down everywhere
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Feb 15, 2010
#34
  • Feb 15, 2010
  • #34
Not here brother.
Adam95GT
2,564
Burlington, NJ
Feb 15, 2010
#35
  • Feb 15, 2010
  • #35
it should get moving over on the bullet dont worry.
Q
qwikcobra
12
Mooresville
Feb 15, 2010
#36
  • Feb 15, 2010
  • #36
You'll like BS3 it is a good system, I was on the fence about it but went with Fast xfi again, their tech support has been great. They always point me in the right direction when I have or had trouble setting it up. Good luck with AEM the only AEM thing I have is thier map sensor, it will be the last AEM product I buy.
4tun8
172
Classified
Feb 15, 2010
#37
  • Feb 15, 2010
  • #37
AEM is a decent system, it's a shame their C/S is a joke. You have to pay for a fault test? Really?
black91'GT
Orlando, Fl
Feb 15, 2010
#38
  • Feb 15, 2010
  • #38
A friend of mine and I have had nothing but trouble with his AEM in his 92' coupe. I agree unfortunately the customer service is horrible.
Killercanary
The car that set the bar.
Altoona, PA
Feb 16, 2010
#39
  • Feb 16, 2010
  • #39
Great, I'm getting ready to do the EPM and now I read this. I can't imagine starting all over again with a new system...
YEAHLOH95
1,249
EVERETT,PA
Feb 16, 2010
#40
  • Feb 16, 2010
  • #40
yeah paul but now that you know what to check for, you can make sure yours will work before trying the coil on plug conversion
  • 3
  • dan50
  • Jul 18, 2026
dan50
Am I crazy? Dad looking to buy 69 as daily
  • stonerCPA
  • Oct 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Nov 12, 2026
ctandc
C
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
