There is a good write up on this in the salvage yard sticky but, here is my question. I know from what I have read that the drive shaft needs to be from a 92-97 AWD but, today while at a local yard, I found a 10 of 94 aerostar that said ELECTRONIC 4 WHEEL DRIVE on the side. Will that drive shaft work or should the van have AWD on it somewhere instead? I would have taken it while I was there but I got there late in the day & came poorly prepared to remove it. I only had a couple wrenches with me and bent my 12 mm trying to remove the bolts. I just wanted to know if this shaft will work before I waste my time going back with bigger equipment.
