AFR 165, 185 or Trickflow
  • Thread starter Thread starter Mustang_Punk
  • Start date Start date Jul 1, 2006
1 of 2 Next Last
Mustang_Punk
224
Sac, Ca
Jul 1, 2006
  • Jul 1, 2006
Which would be best on a 302 soon to be 347 and future kenne bell?
Everybody says AFR but the Trickflow seem just as good, of course none of the mags will EVER compare what I want to buy!
fidstang
307
South Lansing
Jul 1, 2006
  • Jul 1, 2006
AFR 185 or Twisted Wedge will be great. I would go with the TW's because you are going to put them on a stock bottom. AFR185's would require you to flycut the pistons. Both are great heads and flow close. Both will respond very well to porting. I vote for TW's, just slap them on till the rebuild and then port them while stroking the block.
Mustang_Punk
224
Sac, Ca
Jul 2, 2006
  • Jul 2, 2006
Yeah I was gravitating towards the TFS heads but everybody on Calstangs says AFR, they seem almost the same and my cam in TFS so ya...
TurboSnake95
1,402
Spanaway, Washington
Jul 2, 2006
  • Jul 2, 2006
You dont flycut the piston for AFR 185's I think you have the heads confused.
Mustang_Punk
224
Sac, Ca
Jul 2, 2006
  • Jul 2, 2006
maybe he thought of the 205's
Rick 91GT
Mustang Master
95
99
PA
Jul 2, 2006
  • Jul 2, 2006
Depending of the block height (it varies from FORD) and cam most of the time a AFR 185 will require you to enlarge the valve reliefs on a STOCK shortblock, or atleast widen the eyebrow so the valve does not hit on the outside edge.
You mentioned a 347 so I would go with the58cc 185's, you'll have to be careful with rocker and valve cover selection so you can fit it under the KB with out a spacer.
R
R2D2
Jul 2, 2006
  • Jul 2, 2006
Im partial to wedges since I been working with them since the beginning, and can make them work like no tommorrow
Rick 91GT
Mustang Master
95
99
PA
Jul 2, 2006
  • Jul 2, 2006
When fully worked people would be amazed at how far a TW head can go...
Are you the owner of Intake Trends??
R
R2D2
Jul 2, 2006
  • Jul 2, 2006
Ya wedges are great when worked, as for intake trends, yes and no. Im more the money behind things.
M
mackey
1,284
Beverly, Massachusetts
Jul 2, 2006
#10
  • Jul 2, 2006
  • #10
Go with the 185s if you aren't planning on porting the TW before you put them on. I like my TWs but in your case it may be easier just to go with the 185s.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jul 2, 2006
#11
  • Jul 2, 2006
  • #11
Get the Twisted Wedges.
The AFR 185's will need some flycutting.
The Twisted Wedge heads can be ported nicely for when you go with the supercharger.
Get a different block. A4/Dart
I would get a more blower friendly combustion chamber (cc) for the heads since you will be going blown.
Mustang_Punk
224
Sac, Ca
Jul 2, 2006
#12
  • Jul 2, 2006
  • #12
how about the TWs that are CNC's from the factory?
not much more than the regular ones
R
R2D2
Jul 2, 2006
#13
  • Jul 2, 2006
  • #13
just casting flash clean up, far from maxxed out
fidstang
307
South Lansing
Jul 2, 2006
#14
  • Jul 2, 2006
  • #14
I have always been a fan of trickflow and Edelbrock. Dependable and great products for the price.
sbftech, how much do you charge for port work on TW's?
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,240
2,948
224
Vass, NC
Jul 2, 2006
#15
  • Jul 2, 2006
  • #15
Decide whether you want to port the heads or fly cut the pistons. If the former, go with TFS. If the latter, go AFR.
Or, if you're not concerned with the hp you'll give up and you don't want to flycut, go with either the 165s or the TWs. It's a pretty close toss-up stock. I'd go with the TWs since they're cheaper and you'll have more room for porting later.
Chris
fidstang
307
South Lansing
Jul 2, 2006
#16
  • Jul 2, 2006
  • #16
I'd go with what you are comfortable with doing. I went with bigger valves and bought the Isky cams piston notching tool. THe 2.02" intake valve on my setup would hit the sides of the stock valve reliefs. But, I felt comfortable doing this so I went with the bigger valves. If you don't think you can do that or don't want to take the time. Then just slap on the heads that won't have any clearance issues and be done with it. Any of the heads listed will be great on your motor and even better with the blower. Yes, the 165 will have less HP then the two others. But, only on paper, chances are the loss of HP won't affect the ET's greatly.
JBeezy53
559
Sacramento, Ca
Jul 2, 2006
#17
  • Jul 2, 2006
  • #17
I use to be a big AFR fan but I think the TWs will give you more room to grow with, if you decide to have them ported in the future.But you really cant go wrong between the AFR 185s and the TWs.
Rick 91GT
Mustang Master
95
99
PA
Jul 3, 2006
#18
  • Jul 3, 2006
  • #18
The key will be if you go with a new shortblock like the 347 you previously mentioned.
David, you've been hanging over on the corral too much..lol Blower combustion chamber??? A 58cc head with a 14cc dish still keeps it low 9's:1, and depending on the chamber shape and design it could be more efficent then the large chamber. You are better off with the smaller chamber and the correct piston in all cases.
The CNC TW 185's are a very nice head out of the box.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jul 3, 2006
#19
  • Jul 3, 2006
  • #19
I know, I'm a trouble maker over there for sure...
They don't know but I'm wanting a 347, just working out some school money first for a while...and will see after that...
Your advice is much much stronger than mine...
I was saying the "blower friendly" combustion chamber in cc size. Not shape or piston cc's. The piston cc's are from the valve relief "dimples" mainly right? And the others in the flatness or non-flatness in the pistons right?
I didn't know if you seen the part where he was thinking boost...
Mustang_Punk
224
Sac, Ca
Jul 3, 2006
#20
  • Jul 3, 2006
  • #20
Trickfrows outperformed AFR in MM&FF's 205 test, by only a few hp but oh well, Im pretty sure I'll go trickflow, with a Performer intake?
1 of 2 Next Last
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Help with AFR reading
  • dz01
  • Nov 14, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jan 8, 2025
GOvert
G
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
