I was at a swap meet and looking for aluminum heads and found a deal on some AFR's with 1.7 Crane roller rockers - they looked great but I noticed a wear pattern on the roller rocker tips at the valves where some were exactly in the middle of the roller like I would expect and several were no where near the middle of the roller tip - I could easily see the rocker position seemed to be slightly off where the valve end rides was actually not even on the roller part - maybe 15% of it was hanging off - I did not buy the heads because of this and it got me wondering - is this normal? Did valve float cause this? Are the valves bent? Is the head damaged? etc... There were double valvesprings with a damper on them and everything looked to be not that old or used that long - any ideas?
